[SOLVED] random sequence generation
ashugtiwari
Full Member level 4
Full Member level 4
sequence generation
Hi All,
If given the mean and variance of a distribution how to find the gaussian sequence manually. What is the actual method?
Thanks in advance
Ashutosh
random sequence
There is expression for Gaussian distribution which contains both these parameters and no parameters else. So you can easily regenerate the distribution.
use the expression for gaussian distribution as
e Λ [ (x-µ)² / σ² ]
where x = variable
µ = mean
σ = variance
