darla1
Full Member level 3
![Full Member level 3](/styles/images/ranks/elevel3.gif)
dear all
i am charging lead acid battery using full bridge topology, when i check the output current with resistive load (8A) the waveform is good i.e it is in continues and having ripple current of 2A pk-pk.
next i connected the battery, the current waveform is good upto 3 amps, beyond 3 amps the output current is going to pk pk 16A. the waveform is not good it is going to 1amp to 16 amp.
i did not understand why the system is behaing like this.
can any body explain this problem.
thanks and regards
ramesh
thanks and regards
ramesh
