kev241
Newbie level 3
555 timer power supply
Hi I hope someone can assist me with a small design question regarding a 555 timer IC.
Can a 555 ic be operated using a negative power supply? with the the usual positive voltage connected to ground?
I was given a circuit to power a 555 ic using a -5v connected to pin 1 and 6 with pin 4 and 8 grounded and am uncertain how this is supposed to work from looking at the datasheet of the 555 timer.
The 555 is used in atstable mode to pulse light source at 9.25 Hz with a 50% duty cycle. It is similar circuit to the one on thread by k7elp60.
Here is the circuit:
This was a working circuit and i didnt question it till it stopped working.
