MATlab: How to expand an array
RollingEEE
Full Member level 3
Full Member level 3
Bangladesh
matlab repeat vector
I am looking for a code that will repeat each column of a vector to produce a new vector. My code is extremely time consuming. Even matlab suggests not to use an array that gradually 'blows up'
function y = expand(b, m)
A = [];
    n = length(b);
    for i = 1:n
    A = [A ones(1, m) .* b(:, i)];
    end
y = A;
Can any one help?
matlab array
its working for small values
what input you are giving please specify
expand matrix matlab
It works for all values. But if the matrix is large (say 4x2000), it takes a hell lot of time
matlab repeat array
yeah it will take because it has to do a lot of calculation and then to store it in a variable in RAM or HDD whatever but you require a really fast computer to work with such big calculations
matlab expand
Any one else with some actual skills of matlab?
matlab repeat
For a matrix size of 4x2000, it will always take a lot of time.
Matlab often gives this warning that the variable might be growing, but usually it does not effect the performance too much.
Anyway, if you dont want to use this method, then ask the user to input the size of the matrix vectors (b,m) as the input to the function, then create a variable like
A = zeros(1,L), where L can be the length of L
This way the variable A will not be growing inside the loop
Of course, you'll then need to make some modifications to the code, where you assign values to variable A, like this A(i) = ....
where i represents the current index of the loop from 1:n
Try this procedure, then compare via the Matlab Profiler to see which process took more processing time.
matlab expand matrix
I am looking for a code that will repeat each column of a vector to produce a new vector...
So if I understand you correctly, you want a vector
a = [1 2; 3 4];
and you pass expand (a, 3) you get
1 1 1 2 2 2
3 3 3 4 4 4
if this is correct, the proper way of implementing it it is like this:
function y = expandB(b, m)
y=reshape(repmat(b',1,m)', length(b:),1)), m*length(b(1,: )));
That's it. As a test, I passed
b = ones(100, 1000)
m = 500
my version took 1.318641 seconds. Thats tiling out a 100x1000 matrix 500 times!
Communications_Engineer said "For a matrix size of 4x2000, it will always take a lot of time"
This is wrong, wrong, wrong. Matlab LOVES to process matrices, you got gotta understand how it does it so you don't artificially slow it down.
The general rule for Matlab is "If you are using a for loop, you are probably doing it wrong."
Seriously, Matlab is NOT optimized for looping. The more you learn to vectorize everything, the better your programs will work
    RollingEEE
matlab expand array
Thanks. But I bet my answer is the best.
use kron (A, ones(1, n))
to expand matrix. One line and simple
Added after 2 minutes:
Huh, my code used to take 15 mins, now it takes 2 seconds to run with a 4 x 80000 matrix
expand vector matlab
Nicely done with the use of the 'kron' function. You are clearly making a lot of improvement in your Matlab skills, RollingEEE.
However, my solution is still faster. This function will compare the two:
tic
disp('using reshape/repmat')
toc
tic
y = kron(b, ones(1,m));
disp('using kron')
toc
reshape/repmat takes just about 1/2 the time to run. Granted, we are talking about the difference between 1 second and 2 seconds, but this is a forum, so it is worth comparing different solutions to the same problem.
Mostly, this whole situation really illustrates the need to understand how Matlab operates, and the difference it makes when an intuitive solution (the use of a for loop) is used instead of learning about the programming environment.
Added after 7 minutes:
hmmm, interesting. It turns of that for an m x n matrix, if n >> m, mine works faster, but if m >> n, then yours works faster.
I'll have to ponder this for a while, and see if I can come up with a reasonable explanation
    RollingEEE
matlab expand vector
You are probably right, but I don't think the reshape method works when you are expanding matrix, like
can it make
[1 2 3; 4 5 6]
as [1 1 1 2 2 2 3 3 3; 4 4 4 5 5 5 6 6 6] ?
Kron can do it
for loop matlab expand
Yes, the two functions are equivalent. Try it out for yourself!
>> a
a =
1 2 3
4 5 6
>> expandB(a, 3)
Elapsed time is 0.000406 seconds.
ans =
1 1 1 2 2 2 3 3 3
4 4 4 5 5 5 6 6 6
