zhipeng
coplanar waveguide design
I have two quick questions on CPW.
Different set of (W, G) values for a CPW can give the same impedance. If the conduction loss is the main concern, one could increase W and correspondingly G to reduce the loss due to not-infinite conductance (worsen by skin effect) of copper. What's the limit as one simply increases W and G, if board area is not yet a concern? What typical W people typically use, say 1 oz copper on two sheets of 2116 FR4 at 2GHz for 50 Ohm?
Another question. Is there a way to make Agilent ADS automatically generate layout with bended CPW from schematics?
Thank you very much!
