Looking for a C 8051 code for 24cxx
SphinX
Advanced Member level 3
EGYPT
I search for code written in c for 24cxx series.
I use ATMEL 8051 microcontroller.
Thanx
24cxx
hi
u will find i2c device (24c02,04....) with 8051 core ,
see bascom software
Masud Rana
Matrix Electronics Fourm
Dhaka
Bangladesh
8051 i2c code
Hi
Take a look at Keil
Using and Programming the I2C BUS Application Note 153
24c16 eeprom interfacing 8051 keil
Hi.. All
Look at this.
I've Source code (KEIL uVision) and Proteus ISIS simulation for read&write eeprom (I2C communication) use eeprom 24AA256.
This code is writing to the eeprom at address 0x0010 and the value is 0x16.
after done, the program will read the address writed in previous (0x0010).
The result will be displayed on the seven segment at Port0.
thats all.
regards
code 24c16
I didn't saw this!! ....
26 Apr 2004 15:18.
My God!! (@0@)"
    V
8051 c code example for sevensegment
hi herlambang
that was a good code to start with I2C but if want to store five data's is it possiblr to do with that code..
can you please illustrate it with some example.i am newbie to I2C
Venkat.S
Re: 24cxx c 8051 code?
Thank you Mr.herlambang
Its very helpful.:D
24cxx c 8051 code?
eeprom has a (relatively) long write time (5 - 10ms) when it does not acknowledge any outside command until the write-operation has ended.
you can program a hard delay (like you have done), or to implement acknowledge polling as the datasheet (not so clearly) articulated.
this will typically bring an improvement in throughput, especially if you do lots of eeprom writes.
