How to make hex. MMC Interface with ATMega 16
Cool Sun
atmega mmc
I wanna interface external data memory with atmega 16. For this purpose I choose MMC because its code is already written and is on web with. The code is.
* Chip type : ATmega16
* Clock frequency : 2457600Hz
#include <avr/io.h>
#include <avr/interrupt.h>
#include <avr/signal.h>
#include <inttypes.h>
#include <avr/iom16.h>
#define F_OSC 2457600 /* oscillator-frequency in Hz */
#define UART_BAUD_RATE 9600
#define UART_BAUD_CALC(UART_BAUD_RATE,F_OSC) ((F_OSC)/((UART_BAUD_RATE)*16l)-1)
#define SPIDI 6 // Port B bit 6 (pin7): data in (data from MMC)
#define SPIDO 5 // Port B bit 5 (pin6): data out (data to MMC)
#define SPICLK 7 // Port B bit 7 (pin8): clock
#define SPICS 4 // Port B bit 4 (pin5: chip select for MMC
char sector[512];
void delay_ms(unsigned short ms) {
unsigned short outer1, outer2;
outer1 = 200;
while (outer1) {
outer2 = 1000;
while (outer2) {
while ( ms ) ms--;
outer2--;
outer1--;
void usart_putc(unsigned char c) {
// wait until UDR ready
while(!(UCSRA & (1 << UDRE)));
UDR = c; // send character
void uart_puts (char *s) {
// loop until *s != NULL
while (*s) {
usart_putc(*s);
s++;
void init(void) {
// set baud rate
UBRRH = (uint8_t)(UART_BAUD_CALC(UART_BAUD_RATE,F_OSC)>>8);
UBRRL = (uint8_t)UART_BAUD_CALC(UART_BAUD_RATE,F_OSC);
// Enable receiver and transmitter; enable RX interrupt
UCSRB = (1<<RXEN)|(1<<TXEN)|(1<<RXCIE);
//asynchronous 8N1
UCSRC = (1<<URSEL)|(3<<UCSZ0);
// INTERRUPT can be interrupted
// SIGNAL can't be interrupted
SIGNAL (SIG_UART_RECV) { // USART RX interrupt
unsigned char c;
c = UDR;
usart_putc(c);
void serialterminate(void) { // terminate sent string!!!
UDR = 0x0d;
UDR = 0x0a;
void SPIinit(void) {
DDRB &= ~(1 << SPIDI); // set port B SPI data input to input
DDRB |= (1 << SPICLK); // set port B SPI clock to output
DDRB |= (1 << SPIDO); // set port B SPI data out to output
DDRB |= (1 << SPICS); // set port B SPI chip select to output
SPCR = (1 << SPE) | (1 << MSTR) | (1 << SPR1) | (1 << SPR0);
PORTB &= ~(1 << SPICS); // set chip select to low (MMC is selected)
char SPI(char d) { // send character over SPI
char received = 0;
SPDR = d;
while(!(SPSR & (1<<SPIF)));
received = SPDR;
return (received);
char Command(char befF, uint16_t AdrH, uint16_t AdrL, char befH )
{ // sends a command to the MMC
SPI(0xFF);
SPI(befF);
SPI((uint8_t)(AdrH >> 8));
SPI((uint8_t)AdrH);
SPI((uint8_t)(AdrL >> 8));
SPI((uint8_t)AdrL);
SPI(befH);
SPI(0xFF);
return SPI(0xFF); // return the last received character
int MMC_Init(void) { // init SPI
char i;
PORTB |= (1 << SPICS); // disable MMC
// start MMC in SPI mode
for(i=0; i < 10; i++) SPI(0xFF); // send 10*8=80 clock pulses
PORTB &= ~(1 << SPICS); // enable MMC
if (Command(0x40,0,0,0x95) != 1) goto mmcerror; // reset MMC
st: // if there is no MMC, prg. loops here
if (Command(0x41,0,0,0xFF) !=0) goto st;
return 1;
mmcerror:
return 0;
void fillram(void) { // fill RAM sector with ASCII characters
int i,c;
char mystring[18] = "Captain was here! ";
c = 0;
for (i=0;i<=512;i++) {
sector = mystring[c];
c++;
if (c > 17) { c = 0; }
int writeramtommc(void) { // write RAM sector to MMC
int i;
uint8_t c;
// 512 byte-write-mode
if (Command(0x58,0,512,0xFF) !=0) {
uart_puts("MMC: write error 1 ");
return 1;
SPI(0xFF);
SPI(0xFF);
SPI(0xFE);
// write ram sectors to MMC
for (i=0;i<512;i++) {
SPI(sector);
// at the end, send 2 dummy bytes
SPI(0xFF);
SPI(0xFF);
c = SPI(0xFF);
c &= 0x1F; // 0x1F = 0b.0001.1111;
if (c != 0x05) { // 0x05 = 0b.0000.0101
uart_puts("MMC: write error 2 ");
return 1;
// wait until MMC is not busy anymore
while(SPI(0xFF) != (char)0xFF);
return 0;
int sendmmc(void) { // send 512 bytes from the MMC via the serial port
int i;
// 512 byte-read-mode
if (Command(0x51,0,512,0xFF) != 0) {
uart_puts("MMC: read error 1 ");
return 1;
// wait for 0xFE - start of any transmission
// ATT: typecast (char)0xFE is a must!
while(SPI(0xFF) != (char)0xFE);
for(i=0; i < 512; i++) {
while(!(UCSRA & (1 << UDRE))); // wait for serial port
UDR = SPI(0xFF); // send character
serialterminate();
SPI(0xFF); // actually this returns the CRC/checksum byte
SPI(0xFF);
return 0;
int main(void) {
init();
SPIinit();
uart_puts("MCU online");
serialterminate();
MMC_Init();
uart_puts("MMC online");
serialterminate();
sei(); // enable interrupts
fillram();
writeramtommc();
sendmmc();
uart_puts("512 bytes sent");
serialterminate();
uart_puts("blinking LED now");
serialterminate();
// enable PD5 as output
DDRD |= (1<<PD5);
while (1) {
// PIN5 PORTD clear -> LED off
PORTD &= ~(1<<PD5);
delay_ms(500);
// PIN5 PORTD set -> LED on
PORTD |= (1<<PD5);
delay_ms(500);
return 0;
Code Source: http://www.captain.at/electronic-atmega-mmc.php
The files like interrupt.h and other files included are troubling me. I found most of them on web but there is the code for these files not the hex file. When I try to compile them to make hex file, my codeVision displays too much errors. Please guide me which software I should use to make it a hex file and if you have any other working code for MMC with ATMEGA 16 or any other working code for external memory then please post that code. I am using ATMEGA 16.:|
#include <avr/io.h>
If you have these file then please post them because I am not sure that I have right files or not.
atmega16 mmc
those files comes with the AVR-libC! if you are using windows, you could download WINAVR which comes with AVR-gcc avr-libc and other useful tools... Maybe you are using another AVR C compiler...
    Cool Sun
mmc interface
thankx a lot dear. its really helpful. I got what I want. Thank you again...
how to make hex file for atmega32
what about mmc and avr in bascom?
i`m using atmega128, any body help me?
i wanna a good program that certainly works!
Re: atmega mmc
Can you show me the schematics of your design. i am unable to get any idea of the design from your code
#include <avr/io.h>
char sector[512];
outer1 = 200;
while (outer1) {
outer2 = 1000;
while (outer2) {
while ( ms ) ms--;
outer2--;
outer1--;
while (*s) {
usart_putc(*s);
s++;
void init(void) {
// set baud rate
//asynchronous 8N1
unsigned char c;
c = UDR;
usart_putc(c);
UDR = 0x0d;
UDR = 0x0a;
char received = 0;
SPDR = d;
received = SPDR;
return (received);
SPI(0xFF);
SPI(befF);
SPI((uint8_t)AdrH);
SPI((uint8_t)AdrL);
SPI(befH);
SPI(0xFF);
char i;
return 1;
mmcerror:
return 0;
int i,c;
c = 0;
c++;
int i;
uint8_t c;
return 1;
SPI(0xFF);
SPI(0xFF);
SPI(0xFE);
SPI(sector);
SPI(0xFF);
SPI(0xFF);
c = SPI(0xFF);
return 1;
return 0;
int i;
return 1;
serialterminate();
SPI(0xFF);
return 0;
int main(void) {
init();
SPIinit();
serialterminate();
MMC_Init();
serialterminate();
fillram();
writeramtommc();
sendmmc();
serialterminate();
serialterminate();
DDRD |= (1<<PD5);
while (1) {
PORTD &= ~(1<<PD5);
delay_ms(500);
PORTD |= (1<<PD5);
delay_ms(500);
return 0;
#include <avr/io.h>
