Ideal low pass Filter with linear phase and with square S21
jayce3390
Full Member level 6
Full Member level 6
I need to use an ideal filter in ADS circuit simulation. But the component palette doesn t provide ideal filter, only Chebychev, Butterworth...
Is it possible to create ideal filter with linear phase and with square S21?
With SDD?is it a good way?
thank you
Re: Ideal low pass Filter
No. The closer you get to a rectangular response, the worse the phase and time delay distortion. This is part of the physics of a filter that is described by a mathematical polynomial.
    jayce3390
thanks a lot.
Yes kspalla, you suggest me to try in ADS , but how can I set an ideal filter in ADS? You are thinking about SDD component or a ideal filter component exists in ADS?
If yes I don't find it.:|
flatulent, if phase shows 2pi shift, can we consider this linear?
Almost yes, but it's a bit of a cheat. Go to the 'Filters-Bandpass' palette and select
a SAW filter. This is of the high-loss linear phase type.. but ADS lets you set the
loss to whatever you like. Set the passband such that the lower edge of the filter
is at 0Hz or lower (since you probably don't care about negative frequencies). Set
the group delay to whatever you need. Set BWstop (rejection) close to the
passband for a near square S21.
In reality this filter is impossible as a SAW filter, but digitising and implementing
as an FIR filter might be possible(not my speciality!) depending upon the filter
cut-off frequency.
Hope that helps.
Martin
    jayce3390
Ok thank you, indeed SAW filter in ADS provides linear phase if parameter is let to default according to the help, but after simulation the phase is not linear...
if anyone could give me link or documentation to implement low pass filter with equations I will apreciate.
thanks in advance
