What is PCB ident? What is the importance of it?
saumya_85
Full Member level 1
INDIA
u ident on pcb
what is PCB ident?
What should be the minimum height & width for ident?
What is PCB Indent?
It is "ident" not "iNdent".
The ident is the component name, the bit that is usually in white text on the PCB to identify the component.
    saumya_85
What is PCB ident?
if u have space on PCB ,it should be 40/40/8
if it is very dense board,it can go 30/30/6 ..all dimensions are in mils.
u can go further less size but in that case visibility of text will be low
    saumya_85
