winglj
Full Member level 4
screw on PCB?
Hi, everyone.
I have a question of the screw on PCB. I want to put some screw holes on my PCB for fastening it on an enclosure. Can I put the thread on the PCB? Or can I use bolt/nut?
Should I use the major diameter, pitch diameter or minor diameter of the screw? For example, for the 4-40 screw, should I just use the 0.112" diameter for the holes on PCB?
Thanks.
Hi, everyone.
Thanks.
