Explanatio of 16-QAM and QPSK statements
Aya2002
Iraq
can anybody explaine the following please:
16 QAM with code rate of 1/2 coding to give 2 bits per symbol.
and
QPSK with code rate of 3/4 coding to give 1.5 bit per symbol.
also if you know the reference, please advise me
thanks in advance.
qpsk coding rate
16 QAM produces 4 bits/symbols with an (1/2) rate (bits/symbol) coding will produce
4*(1/2)=2 bits/symbols
2 * (3/4) = 1.5bit/ symbol
whether the explantion is enough for you or are u expecting some other reply.
Happy Learning
    Aya2002
16qam
My Friend,
If i have 128 binary digits and need to use the QPSK modulation, then the number of output symbols will be 64, in each symbol there are 2 bits. Now if i used the QPSK with 3/4 coding, what is the outbut will be?
qam 16 3/4
may i know the clarification also?
Thank you
    Aya2002
16 qam bitrate
At first what is the your bit rate(source bit rate=R_s)?????
if there are k=128 bits for (1/2) rate coder, there are 100% redundant bits (n-k)
i.e., 128 bits. ; n=128+128=256.
so code rate=r=k/n=128/256=1/2.
channel encoder bit rate is given by = R_c= (n/k)*R_s = (256/128)*R_s =2*R_s
where R_s is the bit rate generated by the source.
If R_s is the bit rate which is incoming bits to the encoder.
the o/p of the M-ary modulator in your case QPSK (M=4, in this case)
At the o/p of the M-ary modualtor: symbol rate R_sym
R_sym= R_c / log2 (M) = 2*R_s / log2 (4) = R_s in your case.
Happy learning
    Aya2002
qam bit rate
My friend,
Thank you for your help, but i am asking about the number of output symbols in case of QPSK with code rate of 3/4 coding if the input is 128 bit.
please rectify me if i am asking something wrong. In OFDM i need to know what is the data that i have before i process it by the IFFT block.
Many Thanks
16 qam coding rate
If the i/p bit is transferred at the rate of 128 bits/ sec.
then in case of of QPSK (M=4) with code rate of 3/4 coding
Rc= (3/4)*128 = 96
NO. OF SYMBOLS TRANSFERRED AT THE O/P QPSK MODUALTOR IS : 96/log2 (4) = 96/2 = 48 symbols/sec
i think this will help you to further proceed in your learning.
Happy learning
Added after 5 minutes:
hVE YOU GOT CONVINCED OR ARE YOU EXPECTING ANOTHER BETTER REPLY.
WHETHER YOU CHECKED WITH MY ANSWER ???? I HAVE SHARED MY KNOWLEGE WITH YOU.
KINDLY CHECK WITH THE ANSWER AND DO REPLY ME.
    Aya2002
qam code rate
I donate 50 points for you. Your discussion was very clear and good.
Many thanks.
by the way, there are about 10 new members from Malaysia joined our group all are students of PhD and M.s.c in communications. Most of them are Iraqi students. So that, Please rewrite your answer in the group as this very nice from you
qpsk code rate
Hi Muntather,
"Please rewrite your answer in the group as this very nice from you "
i can't follow this line.
what do you mean by that.....
Happy learning
    Aya2002
qam coding rate
just to put some force in the group. May be this will help some of the members. I do not mean other thing. My Friend,
My goal is to let every one learn.
I am sorry if you understand it in a wrong way.
16 qam symbol rate
How can the (data) rate change? Doesn't the channel encoder just add redundency at the same data rate of the incoming stream.
2*R_s shows that after suppose convolutional encoding the data rate of the encoded symbols is greater than the data rate of the incoming bit stream.
I think the data rate remains same, only that now you have half of the user bits flowing in the same amount of time.
Secondly, the idea about the 1.5 bits/symbol ... I think this is related to information theory, we dont have a 0.5 bit practically. I am completely convinced by the math that you have provided but this shows that in one symbol after encoding there would be equivalent information to 1.5 bits. Even though the symbol would really be carrying 2 bits i.e. 2 bits/symbol
Do you agree? Y/N
qam 16 1/2
ANS: YOU R CORRECT:
i never talk abt data rate change!!!!
all i talk abt
the channel encoder rate ... because of adding redundant bits....
eg in case: for convolutional encoder rate of (1/2)
which means: we require double the bandwidth of the uncoded Systems.....and hence the capacity of the channel needs to be doubled for the . hence R_c=2*R_s
INTREPRETATION:
since BW is a constrainst,
if we cant double the bandwidth of the single user channel: automatically,
ONLY HALF OF THE USER BITS ARE TRANSMITTED in the given channel , utilizing the available BW.
Secondly, the idea about the 1.5 bits/symbol :
suppose if R_s = 3 bit/sec.... encoder rate = (3/4)
R_c=(4/3)R_s =4 bit/sec
Here , we have original bits = 3 bits
redundant bit = 1 bit
At the Modulator o/p , the symbol rate is R_Mod_sym = R_c/log2(M)
for QPSK M=4.
R_Mod_sym = R_c/log2(M) = ( 4 ) / log2(4) = 4/( 2) = 2 symbols /sec
now,
bits/symbol = 3 (bit/sec) / (2 ) (symbols /sec) = (3/2) bits / symbol...
= 1.5 bits/symbol
INTREPRETATION:
we have 3 bits as original bits there are 2 symbols (which has got 2 bits/symbol, in case of QPSK) we get at the o/p of the modulator ......
bits/symbol = 1.5 bits/symbol ..............
Happy Learning.
    Aya2002
16 qpsk
Hi, Im looking for an answer with a problem that I have with my wireless connection.
The antena outside my house has very high signal but the modulation fluctuates too much. For example:
QAM64 3/4
QAM16 1/2
QAM16 3/4
QPSK 3/4
Data ranges for download and upload of 29+
It seems that this fluctuations are affecting my internet connection. I'm experiencing also fluctuations on connection timeouts (Sporadic connection timeout). This is affecting my downloads and other communication that requires stable connection.
Do anyone knows if its possible to fix a wireless antena with just one modulation?
Thanks for any help
QLands
