Big Dot Matrix LED Display Signboard 24x116 pixel
Persian_Men
Junior Member level 1
big led matrix
Hi
I design my dot-matrix led display with pc user interface. You can draw and write any shape and message in pc program and see those in dot-matrix .very easy use.
Support all windows font and you can display a bitmap in dot-matrix.
Just copy pattern in c source and rebuild it . after see simulated dot-matrix in proteus.
1-Run 'Pattern Generator'
2-Draw Pic or Any Message
3-Press 'Generate Pattern'
4-Copy and paste new code in C Source Code
5-Compile C source code with CodeVision
6-Display Result simulated in proteus
7-thank's
Please help me to I can scroll message or picture in dot-matrix. I use mega32 microcontroller to control dot-matrix board. I programming with c language for microcontroller. In bottom you can download it with proteus simulate circuit. Please Help Me….
I don't know how can scroll message in board please help me.
I can't write English very well) )
if 'Pattern Generator' does not work download and install it:
[/url]
dot matrix led display
Hi Persian_Men, can you upload sch for hardware,
regards
matrix led
Hi Thank's
Schematic Uploaded////
dot matrix led
Thanks,
regards but I do not see sch file,
Reactions: jito79
    jito79
led signboard circuit
thanks Persian_Men for the great program.
who can i move the message generated to the right
or to the left continuosly .i wish you the best.
led display source code
You can move the memory one by one right or left with delay than you can get the effect.
is it possible to share the VB Souce Code of the projects?
led display c program source code
thanks senthilkumar i downloaded the (Simulate And Source Code) from the above link i was hopping that the the sentence in proteus will look like it is shifting so moving as for the VB Souce Code of the project it is the same Big Dot Matrix LED Display Signboard 24x116 .can you do something with the codevision to apply the move.
thanks in advance
dot matrix sign board
Persian_Men said:
Hi
7-thank's
[/url]
if you share the VB Souce Code the i will deeply look in to the algo than i modified the codevision code.
is it possible to upload here the VB Source Code?
dot matrix display programming
greaT !!!
but in my PC the software didn't work!
display signboard
The LED Glow in Real Hardware as DIM any one explain how can i improve the Brightness using ULN28003? any help ? any Idea?
led display schematic
segmex said:
greaT !!!
Download VBRunTime6 and install it.
OK
how to generate pattern for led display
can someone send me this schematics in pdf or protel to adenisio @ hotmail.com
thx
matrix led big
you can load the files here. So, everybody can benefit. Aren't it?
thanks...
pattern genrator for led moving message display
please load it here.
matrix led, software
pls can you do me the favor of sending
schematic in gif, jpeg,bmp format to my email: lucrisng@yahoo.com
big dot matrix
hey, thanks for the help...........
I am also doing the same project in my final year.....
