current sensing circuit
amyken
Newbie level 2
Newbie level 2
anyone can help me to search a simple current sensing circuit with the input voltage 12V and the output voltage 5V
current sense circuit
Current Sensing Circuit with I/O Voltages ???????????
Are you trying to find a Voltage Regulator with onboard current sensor and if so what range of current
current sensing circuits
the range of current is 1-10A
high side current sense circuit
There is a range o high-side current monitors that allow you to monitor/measure currents on the supply line (high-side) of a circuit ..
Here is one example:
Another option is to design you own circuit based on the same concept (shunt resistor + opamp) ..
Whatever option you choose you will need a current sensing resistor that is rated for more than 10A and is of mΩs to ≈0.1Ω resistance ..
If I may suggest something, go for 10mΩ (0.01Ω) @ 2-5W resitor ..
Rgds,
IanP
current sensing schematics shunt opamp
i think you need to be a bit clear about your requirements, otherwise Ianp has replied perfectly
sorry for interrupting…
my question is how about to design an ac current meter/analyzer?
it is as what an clamp meter is about…i want to analyze the current in the DB and the data receive will be deliver into microcontroller..
i’m new and dont know much about this topic
