No. it is the boundaries of art work.is it Layout of a Dielectric layer?
No we can.You can't do finite dimension substrate analysis in Momentum...
yes Box mode for closed boundary.But having said that it has a Box mode with approximation for such types of analysis...which is OK...
Manjunatha_hv said:Hello htung,
Agilent Momentum uses formulation of Method of Moments (MoM) & this assumes that substrates go to infinity in all directions (X,Y)...
You can't model Finite substrate block in Momentum...
You can enter Er of dielectric, Height of dielectric, thickness of the conductor, Loss Tangent for EM simulations...
---manju---
Yes, you can define a finite sized box around your substrate.This box will have walls with perfect conductors.is it possible in momentum that we can specify a large metal box under a finite size substrate?
