Ask for help about the non-use pins of the MCU chip
bhl777
Full Member level 6
Full Member level 6
Hi guys, I am doing a MCU Design then I am drawing the PC Poard for the whole circuit. Someone told me that I should connect the pins which are not used to the GND or VDD. For example, in the 14-pin MSP430 chip, I just use 7 of them and the other 7 pins is not used. Should I let them be float or connect them to the VDD or GND? Thank you for helping me out!
just leave them floating
Nandhu
    bhl777
if you used MSP430 ,just leave them floating
    bhl777
I don't use the MSP430, but would suppose it has internal pull ups, so leaving disconnected would not be a problem. Good general logic practice though is not leave floating pins, inputs in particular.
