Hi
Generally I connect the source drain and body to ground. I then give a ramp voltage say 0 to 1.2V in 1.2ps using pwl. now observe the current. I generally remains constant. C= I/(dV/dT) i.e I/(10^11). note the cap befor threshold is differernt from cap after thereshold.
