Problem with triac circuit
Nora
Full Member level 1
My garage, USA
triac circuit
Hello
I've constructed a triac circuit using the suggested circuit on the triac driver's data sheet. It doesn't work and since I don't know what to expect, it would be great to get some troubleshooting help.
I've attached the circuit snip.
There is a pulsing output from the uP that goes to the optocoupler (triac driver MOC3023) that I can see as there is an LED to reflect. I also verified pulsing output with scope.
On the other side of the triac driver, I think I'd expect to see more pulsing, but don't. And since there is no signal whatsoever outputting from the triac driver, there is nothing getting to the gate of the triac.
Datasheet here:
https://www.st.com/stonline/books/pdf/docs/7472.pdf
My load on the 115AC side is only 24ohms. I wonder if it is too small? Does the triac need more load?
Or is one of my parts busted?
Thanks in advance,
Nora
triac troubleshooting
try reversing your triac pins MT1 and MT2:
on the moc 30xx family the moc output MUST be between MT2 and G
and your's is between MT1 and G
this is written nowhere but some triacs dont connect if...
I had the same problem this week...:)
    Nora
troubleshooting triacs
The 1k resistor limits the current in the LED of the opto to only 3mA. The minimum current on the datasheet is more so reduce the value of the 1k resistor. The max allowed current from a PIC is 25mA.
24 ohms on a 115V circuit is 551W. The peak current is 6.8A.
    Nora
how does a triac work
BTW what is TB1 & TB2?
If it is a transformer nothing is going to work
Nandhu
troubleshoot triac
Thanks for replies.
Kripton- I am going to switch MT1 and 2 this week- what a strange thing to NOT print on your datasheet!
TB1 and TB2 stand for terminal block 1 & 2.
Yes, the watts are high. The load is a heater. The triac is rated for more that 6.8A so should be OK.
In the datasheet that I'm looking at- page 3 of 10
www.fairchildsemi.com/ds/MO/MOC3010M.pdf
It says that the LED trigger value (IFT) for a MOC3023 should be 5mA, so yes, more than 3mA. So 5V- 1.2V (LED) / 5mA = ~750ohm. OK, can reduce 1k- thanks for pointing that out!
Nora
triacs moc
Nora
in fact if you look at schematics around the web with a moc30xx, and if the terminals are written, there is always MT2 (or A2) - the moc - and G
but it is not always written
and the triacs are supposed to be reversible between mt1 and mt2
I found once someone that pointed out that fact of mt2 and moc, and as I came on the same problem I remembered it...changed mt1 and mt2 and my triac was switching !!!!
some triacs need this, I dont know why, but it's a fact I experimented really.
my triac was a BTB16-600BW
regards,
triacs sample problem
They are reversible in respect to the load connection, but never reversible regarding gate drive. You can easily identify a low resistance between G and MT1 (A1).
    Nora
problem with triacs
Hooray! It works. I switched MT1 and MT2 and all is well.
I'll switch out the the resister too in the final version so its not so marginal.
Will go and click on "helped me" now.
Cheers!
Nora
