How to interface zigbee/xbee modules with Atmel 8051 controllers?
rizwanspirit
Member level 4
Member level 4
Hi
please tell me that can we interfac xbee module or zigbee transciever ics with atmel 8051 series controllers
any type of material is wellcomed.
zigbee interfacing with 8051
rizwanspirit said:
Hi
you should read the datasheet of the module in question OR post the datasheet here so others can help you.
You also need to specify which 8051 micro controller you are using.
how to interface zigbee with microcontroller
Hi ,
Ya .. You can Interface Zigbee modules with the 8051 series ICs.
just u need to know is the details of the data output type of ur Zigbee interface I.C.
Regards,
Vikeee ..
8051 zigbee
rizwanspirit said:
Hi
drive you 8051 with 3V then connect your RX Xbee to TX of 8051 and also on receiver...then you can send data directly
zigbee interfacing
Thank You brothers
Another Question;
Which is easier to use, ZigBee ICs or Xbee module?
zigbee ics
Buy some modules from meshnetics they are very easy to use and can be hooked to 8051 with ease
zigbee 8051
rizwanspirit said:
Thank You brothers
Another Question;
of course the xbee cause its a module. if you use and IC, you need to go deeper on zigbee.....xbee uses zigbee..where xbee is a complete module that can be use directly line of communication
    rizwanspirit
zigbee 8051 module
Brother i want to know that meshnetics modules are from Atmel ?
