PIC PLC (PIC16F648A based PLC project)
Myself
Member level 3
Member level 3
pic plc
Dear all,
the following link takes you to a really interesting PIC PLC project (PIC16F648A based PLC project):
where you are provided with the PCB files for realizing the PCBs, photos of the project, etc. related to the project.
This project seems to have recently been posted. It includes a main board and extension boards. The main board provides 8 DC (5 V or 24 V) inputs and 8 relay outputs. The same applies to the extension boards, each one has the same 8 DC inputs and 8 relay outputs. The number of inputs/outputs can be extended as many as you want.
The thing is that the project will seem to take 15 months to complete. It will be explained one article per week basis and will be published within a magazine called ELECTRONICS WORLD.
Take care.
Myself :)
plc pic
The first article for this series of articles can be downloaded from the following link:
Take care.
Myself
plc project
Dear all,
here I am posting some photos of this PIC PLC project:
This is the main board of the PIC PLC:
This is the I/O extension board of the PIC PLC:
the following is the connection of two I/O extension boards with the main board:
plc con pic
The second article in the series of articles can be downloaded from the following link:
Take care.
Myself
pic16f648a
Dear all,
The third article in the series can be downloaded from the following link:
Take care.
Myself
picplc
Hi.
Check this out cheap ready PLCs (boards) with PIC microcontrollers and with their program Parsic I think about 160 euro’s you can make easily a PLC.
The program has AND,OR,EXOR gates, up-down counters, multiplexers ,analog inputs, compare, pwm in/out, ADD/SUB/MUL/DIV, uarts, LCD output, monoflpos, delays, clocks etc.
I have it, its great.
Sotiris
pic project
Dear all,
The third article can also be downloaded from the following link:
The forth article in the series can be downloaded from the following link:
Take care.
Myself
basic plc project opensource
An alternative link for the forth article has just been active as follows:
Take care.
Myself
pic based plc
Dear all,
The fifth article can also be downloaded from the following link:
The sixrth article in the series can be downloaded from the following link:
Take care.
Myself
plc com pic
Hey,
Thank`s
Very good
niktesla:D
pic to plc
Dear all,
The seventh article can be downloaded from the following link:
Take care.
Myself
pic16f648a project
Dear all,
The 8th article can be downloaded from the following link:
Take care.
Myself
plc a pic
Dear all,
The 9th article can be downloaded from the following link:
Take care.
Myself
8051 based plc
Dear all,
The 10th article can be downloaded from the following link:
Take care.
Myself
plc+pic
thankyou for this useful links for making our own plc.
but what about if want to connect it through a HMI
plc with pic
In my opinion this project must be considered as an open source PLC project. This project seems to be providing the basics of how to desing and implement a micro based PLC. Every one can add some new features to this project. For example there is no user interface software to draw a ladder diagram for this project. Someone with the ability to do so may contribute to this project. And all other features may be added.
Take care.
Myself
Added after 8 minutes:
Dear all,
The 11th article can be downloaded from the following link:
Take care.
Myself
Dear all,
The 12th article can be downloaded from the following link:
Take care.
Myself
but what about if want to connect it through a HMI ?
hello ,
this is another PLC built by myself
and these are the posible HMI's to connect to it
Dear all,
The 13th article can be downloaded from the following link:
Take care.
Myself
Smile
