Design UVLO (Under Voltage LockOut) in DC-DC Converter?
shaq
Full Member level 5
Full Member level 5
uvlo design
Dear all,
Anyone has the idea on designing UVLO circuit in DC-DC converter?
If I want to design 2.2v of UVLO with 50mv hysteresis, how should I start?
design uvlo circuit
In my case. I just use hysteresis comparator.
Vref is 2.2V, 2.15V.
and comparator output connects to output diasble pin.
circuit under voltage lockout
Basically UVLO is a simple comparator, Input voltage divide by R then compare with Vref. By adjust resistor value you will have 50mV hysteresis.
uvlo comparator
I think using R-string to generate voltage is needed more current consumption.
(unless super large resistor, i.e. Mohm order)
