Johnson
Advanced Member level 2
@ltium's Dashboard
Again NB2DSK reference board,
1) Is LCD as a component? Where is the LCD connector? Is it connected to main board by cable? Indeed I am looking for design rule in that area! How we can put one smaller component beneath of taller one without drc violation?
2) There are two special mounting holes for that TFT/LCD with more than 4-way thermal connector which is not definable in design rules? How we can manage it?
3) Around voltage regulator with KTT package, special via/hole array is used which act as a heatsink. Those holes are not part of component, how we can create it and important issue in the case of similar components, how to reuse it?
