chandregowda
Full Member level 4
- Joined
- Jul 7, 2008
- Messages
- 212
- Helped
- 14
- Reputation
- 28
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Bengaluru/Bangalore, India
- Activity points
- 2,564
hi,
i have designed a wideband coupler(700MHz-6000MHz) using asymmetric multisection stripline configuration. the design was simulated in HFSS and Microwave CST.
In the S-parameters response, HFSS was showing peaks at higher frequencies
after fabrication, the prototype is also showing few peaks at higher frequencies....
how to eliminate these peaks in the response?
this helps me a lot..........
thanking you
chandre
thanking you
chandre
