Synopsys DC installation
gold_kiss
Full Member level 4
Full Member level 4
snpslmd_license_file
Few days back, i think rf_system had given complete installation procedure for IC5.0 (cadence custom design tool).
This time I need help to install synopsys DC 2004. Please give me detailed procedure dear experts.
also mention which all files i need to have ...
awaiting 4 ur response.
Thanks,
Gold_kiss
synopsys installer
INSTALL_README.txt
syn_vV-2004.06-SP2_common.tar
syn_vV-2004.06-SP2_linux.tar
then follow INSTALL_README.txt step 4~6
4.Uncompress and untar the Synopsys Installer file in a separate installer directory.
         % mkdir -p /usr/synopsys/synopsysinstaller
         % mv synopsysinstaller_v1.0.<n>.tar.Z /usr/synopsys/synopsysinstaller
         % cd /usr/synopsys/synopsysinstaller
         % cat synopsysinstaller_v1.0.<n>.tar.Z | uncompress | tar xvf -
  5. Add the installer directory to your UNIX path.
         % set path=(/usr/synopsys/synopsysinstaller $path)
   6. To install the software, enter one of the following installation commands:
         % ./install.now (to use text prompts)
         % ./setup.sh (to use the GUI)
synopsys install
I think the installation parts are straight forward. But I am having trouble on setting up the license and setup the enviroment.
May you please list out the steps to setup the license and also share your enviroment setup source file?
I am using linux.
synopsys dc
You must have the file "synopsysinstaller" for installing the version 2004.06 and later. The older version do not need it.
synopsys installation
From INSTALL_README.txt
Setting Up the User Environment
 To set up your users, you must create a Synopsys source file, or modify
 each user's $HOME setup files (typically .cshrc, .profile, .kshrc, or .bashrc),
 as follows. For tool-specific information, see "Setting Up <product_name>
 for Each User" in the appropriate tool chapter in the Installation Guide.
    1. Set SNPSLMD_LICENSE_FILE, LM_LICENSE_FILE or a tool-specific licensing variable.
       This variable specifies the path to the Synopsys FLEXlm license server.
       Note:
         SNPSLMD_LICENSE_FILE is supported only for tools using the snpslmd Synopsys
         Common Licensing (SCL) daemon. LM_LICENSE_FILE is supported for all Synopsys
         tools (all daemons).
       In the following example, it is assumed that the Synopsys license server
       is using TCP port 27000, the default port. (However, you can specify another
       port by modifying the SERVER line of your site's keyfile--for example,
       "SERVER myserver 8308a297 26585.")
       Example:
         * Add to .cshrc
            setenv SNPSLMD_LICENSE_FILE 27000@myserver
            or
            setenv LM_LICENSE_FILE 27000@myserver
          * Add to .profile, .kshrc, or .bashrc
            SNPSLMD_LICENSE_FILE=27000@myserver; export SNPSLMD_LICENSE_FILE
            or
            LM_LICENSE_FILE=27000@myserver; export LM_LICENSE_FILE
    2. Add the tool executable files to the user path.
       Example:
         * Add to .cshrc:
           set path=(synopsys_root/<platform>/<product>/bin $path)
         * Add to .profile, .kshrc, or .bashrc:
           PATH=synopsys_root/<platform>/<product>/bin:$PATH
           export PATH
       Note:
         For some tools, the appropriate directory of executable files
         is synopsys_root/bin.
    3. Set any tool-specific variables.
       In many cases, tool-specific environment variables must be set.
       Typically, you need to set an environment variable that points
       to the root directory for the Synopsys tool.
       Example:
         setenv SYNOPSYS /path/to/synopsys_root
       Note:
         Not all tools use the $SYNOPSYS environment variable. In some
         cases, other tool-specific variables must be set.  See the
         Installation Guide for details.
synopsys design compiler installation guide
u can see the install guide ... very simple and clear
synopsys dc 2008 install
Hello all
I have problem installing Synopsys DC
I have Synopsys DC 2005.09-sp4 version, tried installaling on fedora 8, got the following error.
ERROR : Failed to execute /uar/synopsys/X-2005.09-SP4/admin/install/syn/bin/install_psyn
Could some one help me to solve this problem
Thankq in advance
