Supercontinuum generation
Manish
Newbie level 5
Newbie level 5
supercontinuum generation
How to simulate supercontinuum generation. Can it be done using rsoft for photnic crystal ?
split-step Fourier method for higher-order Schrodinger equation
coupled mode equations (if four-wave mixing is considered)
Reactions: Manish
    Manish
Can it be done using Rsoft for photonic crystal fibers?
it seems that Rsoft doesn't embed with Raman response coefficient.
to my knowledge, most of SG simulations are done by self-developed codes
Reactions: Manish
    Manish
Are you familier with Rsoft? What are its capabilities in this direction?
Rsoft has many subsystems, but I just used the fullwaves
you can refer to tutorials for its application,
however, I still recommend you to write you own codes for research.
Reactions: Manish
    Manish
What are the capabilities of fullwave for PCF? I saw the tutorials. There is just one example i.e. Tutorial 4. What else can be done? and how? Do you have any ebooks on PCF, Nonlinear fiber optics, or Supercontinuum generation? Please upload. Thanks ...for your response...
