sgil
Newbie level 3
signal **** has a multi source. vhdl error
Hello all,
I am trying to implement the following code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity fir_cu is
Port ( fa : in STD_LOGIC;
fb : in STD_LOGIC;
fc : in STD_LOGIC;
f_d : in STD_LOGIC;
clk : in STD_LOGIC;
reset_n : in STD_LOGIC);
-- Y : out STD_LOGIC_VECTOR (3 downto 0); --try to remove unused output ports..
-- fy : out STD_LOGIC;
-- Busy : out STD_LOGIC);
end fir_cu;
architecture Behavioral of fir_cu is
component icon
port
control0 : out std_logic_vector(35 downto 0)
end component;
component ila
port
control : in std_logic_vector(35 downto 0);
clk : in std_logic;
data : in std_logic_vector(53 downto 0);
trig0 : in std_logic_vector(7 downto 0)
end component;
signal control0 : std_logic_vector(35 downto 0);
signal ila_data : std_logic_vector(53 downto 0);
signal trig0 : std_logic_vector(7 downto 0);
signal cnt : std_logic_vector (7 downto 0);
signal Lstrobe_R1 : std_logic;
signal Lstrobe_R4 : std_logic;
signal Rstrobe_R1 : std_logic;
signal Rstrobe_R4 : std_logic;
signal selR4 : std_logic_vector(1 downto 0);
signal selR1 : std_logic;
signal desel_R1 : std_logic;
signal desel_R4 : std_logic;
signal enable_R1 : std_logic;
signal enable_R4 : std_logic;
signal d_strobe_Ah0 : std_logic;
signal d_strobe_Y : std_logic;
signal a_strobe : std_logic;
signal b_strobe : std_logic;
signal c_strobe : std_logic;
signal d_strobe : std_logic;
signal dummy_busy : std_logic;
begin
i_icon : icon
port map
control0 => control0
i_ila : ila
port map
control => control0,
clk => clk,
data => ila_data,
trig0 => trig0
-- Time Slot 0
T0: process(clk)
begin
if(clk'event and clk='1') then
if (fa= '1' and fb = '1' and fc = '1' and f_d = '1') then
if (reset_n = '1') then
cnt <= "00000000";
end if;
end if;
a_strobe <= '1';
b_strobe <= '1';
c_strobe <= '1';
d_strobe <= '1';
selR4 <= "00";
cnt <= cnt + '1';
end if;
end process T0;
-- Time Slot 1
T1: process(clk)
begin
if (cnt = "00000001") then
dummy_busy <= '1';
Lstrobe_R1 <= '1';
Lstrobe_R4 <= '1';
cnt <= cnt + '1';
elsif (cnt = "000000010") then
enable_R4 <= '1';
selR4 <= "01";
selR1 <= '0';
desel_R4 <= '0';
cnt <= cnt + '1';
elsif (cnt = "00000011") then
cnt <= cnt + '1';
Lstrobe_R1 <= '0';
Lstrobe_R4 <= '0';
enable_R4 <= '0';
elsif (cnt = "00000100") then
Rstrobe_R4 <= '1';
cnt <= cnt + '1';
elsif (cnt = "00000101") then
d_strobe_Ah0 <= '1';
cnt <= cnt + '1';
elsif (cnt = "00000110") then
cnt <= cnt + '1';
end if;
end if;
end process T1;
-- Time Slot 2
T2: process(clk)
begin
if (cnt = "00000111") then
Lstrobe_R1 <= '1';
Lstrobe_R4 <= '1';
cnt <= cnt + '1';
elsif (cnt = "00001000") then
enable_R1 <= '1';
enable_R4 <= '1';
selR4 <= "10";
selR1 <= '1';
desel_R4 <= '1';
desel_R1 <= '0';
cnt <= cnt + '1';
elsif (cnt = "00001001") then
cnt <= cnt + '1';
Lstrobe_R1 <= '0';
Lstrobe_R4 <= '0';
enable_R4 <= '0';
enable_R1 <= '0';
elsif (cnt = "00001010") then
Rstrobe_R4 <= '1';
Rstrobe_R1 <= '1';
cnt <= cnt + '1';
end if;
end if;
end process T2;
ila_data(7 downto 0) <= cnt(7 downto 0);
ila_data(8) <= fa;
ila_data(9) <= fb;
ila_data(10) <= fc;
ila_data(11) <= f_d;
ila_data(12) <= clk;
ila_data(13) <= Lstrobe_R1;
ila_data(14) <= Lstrobe_R4;
ila_data(15) <= Rstrobe_R1;
ila_data(16) <= Rstrobe_R4;
ila_data(18 downto 17) <= selR4(1 downto 0);
ila_data(19) <= desel_R1;
ila_data(20) <= desel_R4;
ila_data(21) <= enable_R1;
ila_data(22) <= enable_R4;
ila_data(23) <= d_strobe_Ah0;
ila_data(24) <= d_strobe_Y;
ila_data(25) <= dummy_busy;
trig0(0) <= fa;
trig0(1) <= fb;
trig0(2) <= fc;
trig0(3) <= f_d;
end Behavioral;
But i get multiple errors - I checked the Xilinx support website to find possible causes but that didn't really help..or I probably don't know what to change exactly... I get the following:
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <desel_R4>
Sources are:
Signal <desel_R4> in Unit <fir_cu> is assigned to VCC
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <Lstrobe_R1>
Sources are:
Output signal of FD instance <Lstrobe_R1>
Output signal of FDSE instance <Lstrobe_R1_ren>
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <enable_R1>
Sources are:
Output signal of FD instance <enable_R1>
Output signal of FDE instance <enable_R4>
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <selR4<1>>
Sources are:
Signal <selR4<1>> in Unit <fir_cu> is assigned to GND
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <selR4<0>>
Sources are:
Signal <selR4<0>> in Unit <fir_cu> is assigned to VCC
ERROR:Xst:528 - Multi-source in Unit <fir_cu> on signal <cnt<3>>
Sources are:
FATAL_ERROR:Xstortability/export/Port_Main.h:127:1.17 - This application has discovered an exceptional condition from which it cannot recover. Process will terminate. For more information on this error, please consult the Answers Database or open a WebCase with this project attached at https://www.xilinx.com/support.
Process "Synthesize" failed
Hello all,
library IEEE;
entity fir_cu is
fb : in STD_LOGIC;
fc : in STD_LOGIC;
f_d : in STD_LOGIC;
clk : in STD_LOGIC;
end fir_cu;
component icon
port
end component;
component ila
port
clk : in std_logic;
end component;
begin
i_icon : icon
port map
i_ila : ila
port map
clk => clk,
data => ila_data,
trig0 => trig0
-- Time Slot 0
T0: process(clk)
begin
cnt <= "00000000";
end if;
end if;
a_strobe <= '1';
b_strobe <= '1';
c_strobe <= '1';
d_strobe <= '1';
selR4 <= "00";
cnt <= cnt + '1';
end if;
end process T0;
-- Time Slot 1
T1: process(clk)
begin
dummy_busy <= '1';
Lstrobe_R1 <= '1';
Lstrobe_R4 <= '1';
cnt <= cnt + '1';
enable_R4 <= '1';
selR4 <= "01";
selR1 <= '0';
desel_R4 <= '0';
cnt <= cnt + '1';
cnt <= cnt + '1';
Lstrobe_R1 <= '0';
Lstrobe_R4 <= '0';
enable_R4 <= '0';
Rstrobe_R4 <= '1';
cnt <= cnt + '1';
cnt <= cnt + '1';
cnt <= cnt + '1';
end if;
end if;
end process T1;
-- Time Slot 2
T2: process(clk)
begin
Lstrobe_R1 <= '1';
Lstrobe_R4 <= '1';
cnt <= cnt + '1';
enable_R1 <= '1';
enable_R4 <= '1';
selR4 <= "10";
selR1 <= '1';
desel_R4 <= '1';
desel_R1 <= '0';
cnt <= cnt + '1';
cnt <= cnt + '1';
Lstrobe_R1 <= '0';
Lstrobe_R4 <= '0';
enable_R4 <= '0';
enable_R1 <= '0';
Rstrobe_R4 <= '1';
Rstrobe_R1 <= '1';
cnt <= cnt + '1';
end if;
end if;
end process T2;
ila_data(8) <= fa;
ila_data(9) <= fb;
ila_data(10) <= fc;
trig0(0) <= fa;
trig0(1) <= fb;
trig0(2) <= fc;
trig0(3) <= f_d;
end Behavioral;
Sources are:
Sources are:
Sources are:
Sources are:
Sources are:
Sources are:
