why apply 0.35 in formula: rise time=0.35* bandwidth
musnag
Newbie level 3
Newbie level 3
could someone please help to describe why number 0.35 is applied in rise time?
thank you in advance.
That was already answered not more than 2 weeks ago:
You can also use the search tool
As you know already tr is the rise time measured between 10% and 90% of steady state output voltage.
Using a simple RC circuit equation....
Vout= Vin(1-exp[-t/(RC)]-------------------------------1 (RC= time constant)
For instance,assuming that Vin=1 V and the 10% voltage is obtained at time t1..the eqn 1 becomes
0.1= 1-exp(-t1/(RC))------------------------------------2
And assuming 90% voltage is at time t2
0.9=1-exp(-t2/(RC))-------------------------------------3
Rise time tr= t2-t1
i.e tr=eqn3 - eqn2
If you solve this,you will get tr=2.197 RC----------------4
Also we know that cut off frequency is defined as
fc= 1/[2.pi.(RC)]
from 4 fc=BW= 0.35/tr-----------------------------------5
Clear now..????
Ciao,
Shiva :D
Reactions: ln023
    ln023
thank you both for answer and clarification.
