why can not set the calculation in HFSS?
John_li
Full Member level 5
Full Member level 5
Hi all,
The first time using HFSS optimization fuction,and when I edit calculation: AxiaRatio:
(procedure:Name:AxiaRatio…Report Type item :“Far Fields”…solution item” Setup:LastAdaptive…Category:Axia Ratio…Quantity”AxiaRatioValue”…Function:<none>),and add in,but in vain.Can anyone tell me how to solve it?
Thank you in advance,
why can not set the caculation in HFSS?
resend
Re: why can not set the caculation in HFSS?
anyone can help me how to set axial ratio in parametric calculation item?
thank u,
I have checked your file ...
The first problem is the air box , to define the air box as radiation boundary for the such antenna you have to select all the faces except the face under tha antenna.
regards
    John_li
Thank for Mustafa's reply.You are right,i have modified the radiation boundary.
Another hand,the problem is till.
Anyone can give me a hand ?
