Problem of bottom up flow in running DFTC
hgby2209
Full Member level 2
Full Member level 2
test_use_test_models
I use test_model in Hierarchical Scan Synthesis Flow .....
sub1 creat test_model1 (sub1.ctldb) & write out sub1.db
sub2 creat test_model2 (sub2.ctldb) & write out sub2.db
when I read .db & .ctldb in top level, the following Warning display:
Warning: Design 'sub1.db:sub1' comes before design 'sub1.ctldb:sub1' in the link_library; 'sub1.ctldb:sub1' will be ignored. (UIO-92)
Can anyone tell me how to fix this problem, when I need read in .db & .ctldb in top level ?
I find the solution for this issue :
set test_use_test_models true;# enable to creat & read test model, the test model will write out via "write -f db"
so if I set test_use_test_models to true, the I don't need to write test model.
The .db will include the test model.
