wanbong
Newbie level 5
pic16f877 lcd
hi guys, I'm just an newbie with PIC
I'm trying to control the LCD 16x2 (model SC1602-B) with a PIC 16f877
The simulation of my code on the Proteus 7 can run but when I work with real thing it couldn't print out anything
please help me out, below is my code
Added after 5 hours 48 minutes:
after I ground all the unused pins, there is array of blocks appear in the second line the LCD still can not print out anything
* PORTB bits 0-3 are connected to the LCD data bits 4-7 (high nibble)
* PORTA bit 2 is connected to the LCD RS input (register select)
* PORTA bit 3 is connected to the LCD EN bit (enable)
* To use these routines, set up the port I/O (TRISA, TRISB) then
* call lcd_init(), then other routines as required.
//Define compiler error message.
#ifndef __CPU_16F877__
#error "This program is tailored for PIC16F877 controller"
#endif
//Include required header files here.
#include "io16f877.h" //the hardware register definition file.
//-----------------------------------------------------------------delay---------------------------------------------------
void DelayUs(int count)
int i;
int j;
for(i=0;i<count;i++)
for(j=0;j<5;j++);
//This for loop has 5 NOPs & wastes 1 uS for our PIC clock frequency of 20MHz.
void DelayMs(int count)
int i;
{DelayUs(4000);}
#define LCD_RS RA2 // Register select
#define LCD_EN RA3 // Enable
#define LCD_STROBE ((LCD_EN = 1),(LCD_EN=0))
/* write a byte to the LCD in 4 bit mode */
void
lcd_write(unsigned char c)
PORTB = (PORTB & 0xF0) | (c >> 4);
LCD_STROBE;
PORTB = (PORTB & 0xF0) | (c & 0x0F);
LCD_STROBE;
DelayUs(40);
* Clear and home the LCD
void
lcd_clear(void)
LCD_RS = 0;
lcd_write(0x1);
DelayMs(2);
/* write a string of chars to the LCD */
void
lcd_puts(const char * s)
LCD_RS = 1; // write characters
while(*s)
lcd_write(*s++);
/* write one character to the LCD */
void
lcd_putch(char c)
LCD_STROBE;
LCD_STROBE;
DelayUs(40);
* Go to the specified position
void
lcd_goto(unsigned char pos)
LCD_RS = 0;
lcd_write(0x80+pos);
/* initialise the LCD - put into 4 bit mode */
void
lcd_init(void)
LCD_RS = 0; // write control bytes
DelayMs(15); // power on delay
PORTB = 0x3; // attention!
LCD_STROBE;
DelayMs(5);
LCD_STROBE;
DelayUs(100);
LCD_STROBE;
DelayMs(5);
PORTB = 0x2; // set 4 bit mode
LCD_STROBE;
DelayUs(40);
lcd_write(0x28); // 4 bit mode, 1/16 duty, 5x8 font
lcd_write(0x08); // display off
lcd_write(0x0F); // display on, blink curson on
lcd_write(0x06); // entry mode
void IniPort()
ADCON1=0x06;
TRISA=0x00;
TRISB=0x00;
PORTA=0x00;
PORTB=0x00;
char text[]="len di\n";
int count=0;
void main(void)
IniPort();
lcd_init();
while (text[count]!='\n')
lcd_putch(text[count]);
count++;
DelayUs(100);
while(1){}
