Parallel Coupled Strip line filter
danesh
Full Member level 3
Full Member level 3
parallel coupled filter
hi guys,
i wanted to design parallel coupled filter. i having trouble in calculating the width and the saparation between two strip line. Obtained:
Dielectric constant ,er= 2.55
Thickness, H=0.5inch
Even mode impedance=82.53ohm
odd mode impedance =37.6ohm
appreciate your help. thanks
Hello danesh,
I have used the following website link for calculating coupled stripline...
http://www.ideaconsulting.com/dstrip.htm
Enter dimensions:
Trace width (W) 90 mils
Trace thickness (T) 1.5 mils
Trace spacing (S) 7.5 mils
Distance between planes (B) 500 mils
Relative Dielectric constant (Er) 2.55
Differential Trace Impedance 82.3 ohms
Also you can use for other Transmissionline calculations a free TXLINE from AWR
http://web.awrcorp.com/Usa/Products/Optional-Products/TX-Line/
By the way AWR Microwave Office has good number of Stripline circuit models which will be useful for quickly designing circuits....
---manju---
danesh said:
hi guys,
base on presented value on book microwave filters impedance matching network and coupling structure
the width =0.236 inch
separation 0.021inch
you can also use ADS
Reactions: rj45
    rj45
