so lower dft coverage, why?
HolySaint
Full Member level 3
Full Member level 3
Mars
tetramax fastscan coverage
Here i use estimate_test_coverage commond to estimate the testcoverage
what a low testcoverage
RPT
#patterns #faults #ATPG faults test process
stored detect/active red/au/abort coverage CPU time
Begin deterministic ATPG: #uncollapsed_faults=1755508, abort_limit=10...
Warning: Chain test pattern failed contention checking (ID=542). (M430)
0 77035 1673479 1013/2772/1173863 8.77% 513.36
Warning: 1152726 faults aborted during contention prevention. (M139)
Pattern Summary Report
#internal patterns 0
Uncollapsed Stuck Fault Summary Report
fault class code #faults
Detected DT 77035
Possibly detected PT 155113
Undetectable UD 142983
ATPG untestable AU 11499
Not detected ND 1518366
total faults 1904996
test coverage 8.77%
Information: The test coverage above may be inferior
than the real test coverage with customized
protocol and test simulation library.
who can tell me which part may be wrong?
the design i load is produced by DC
Added after 3 minutes:
when i use preview_dft to list the reg,
i find almost all regs are ready to insert dft
do i understand right?
chain test pattern failed contention checking
You should check the dft_drc report. The report will tell u the dft violation information such as D1.D2.D3.... . Then fix them
    HolySaint
test coverage dft
thx , i'll have a try.
if more violation is found,fix the timing in dc script can help,is that right?
dft+coverage
if the dft script is correct , and autofix does not work , u should change the RTL code to improve the dft coverage.
dft_drc in dft
mostly the controllability and observability cause problem.
you could try to report scan chain cell.
what I impressed is that some part of design is not correctly inserted into scan chain.
    HolySaint
dft violation
there is no pattern is generated becasue of the contention violation. i dont know how the DC is calculating cvoerage.
can you try in tetramax or fastscan to check the coverage estimation.
in tetramax, issue " run drc " command, this will give you the all the deatils to violations..
    HolySaint
dft atpg script
thx for everyone
i'll try tmax to detect it again
