zingkov
Newbie level 3
sonnet em vs hfss
Hi everyone! I am a newbie in both RF & HFSS. Therefore, before I start performing simulation for my new design using HFSS, I tried to verify my setting (in HFSS) by comparing the result obtained with those of SONNET and Momentum (published in a journal paper). It's a simple problem concerning a square spiral inductor.
I found out that SONNET gave a great comparison with the Momentum result. However, HFSS result seemed to be very different, particularly for the inductance value. The self-resonant frequency of the spiral inductor seemed to fall at a very high frequency compare with those in SONNET & Momentum.
I then noticed that in most journal papers the inductance peak is not as sharp as the one which appeared in HFSS result. I wonder whether I did something wrong in HFSS modeling. I actually more or less followed the tutorial in HFSS. Attached please find the results and HFSS file.
Any advice or comment is truly welcomed and appreciated. Thanks.
