How to find number of one's in a vector in single clock
megastar007
Member level 4
Member level 4
Munich
can any one tell me the circuit for finding number of 1's in a vector ..say 8 bit vector in a Single clock cycle. output should be 4 bits(bcos all 8 bits can be one)
An easy way is use a parallel eeprom. You can use the address as input data, and then data will be the result. You must program the eeprom with some like this:
This is an example to count just 4 bits, but for more bits is the same
Address Data
A3 A2 A1 A0 D2 D1 D0
0 0 0 0---->0 0 0
0 0 0 1---->0 0 1
0 0 1 0---->0 0 1
0 0 1 1---->0 1 0
0 1 0 0---->0 0 1
0 1 0 1---->0 1 0
0 1 1 0---->0 1 0
0 1 1 1---->0 1 1
1 0 0 0---->0 0 1
1 0 0 1---->0 1 0
1 0 1 0---->0 1 0
1 0 1 1---->0 1 1
1 1 0 0---->0 1 0
1 1 0 1---->0 1 1
1 1 1 0---->0 1 1
1 1 1 1---->1 0 0
Adder or LUT if the number of bits in the vector is small.
