how to make Dipole Antenna Through Microstrip?Help plz!!!
telecom_engr
Newbie level 2
Newbie level 2
how to build dipole antenna
hi guys...im studying telecom engrng n i got semester project on ""how to make a dipole antena through microstrip."" kindly help me in building it from very basic ideas...i mean tell me how n from where to start n wat r the basic things to consider n etc.....
how to make dipole antenna
maybe you can make each arm λ/4 long, resulting to overall λ/4 length. then, for 50Ω transmission, you can tune your antenna through simulators like HFSS.
Attached is a tutorial for a dipole printed on a dielectric substrate design using HFSS. maybe it might help
For the feed, if you have an unbalanced transmission line coming to your antenna, you need to make it balanced.
Hopefully, this helps.
how to make a dipole antenna
thanx mate...i will try n let u knw.....once again thank u very much
