Combinational or Sequential Multipliers ?????????
natg9
Member level 3
Member level 3
sequential multipliers
Hi all
i have this doubt , as to which of the two is better in terms of area, timing ??
please list out the various methods and advantages
thanks to all
combinational and sequential multiplier
Combinational multipliers are slow and take a lot of area.
Sequential multipliers are fast and take less area.
Sequential multipliers may take a number of clock cycles to produce a result. So even they can work on high frequency clock, but the latency in terms of absolute time go get an output may be more or equal to that of a combinational multiplier.
Hope it helps
Kr,
Avi
    natg9
Hi Avimit
Now I am aware of the fact that inc combinational multipliers area is more and speed is slower then do we never use combinational multipliers i want to know this ?
i am in a project that demands higher speed so i have opted for a seq multiplier but i am not able to decide which seq multiplier will give me optimum speed
please reply pal
regards
natg
As I said the sequential mutliplier can use a number of clock cycles, it may not be the best solution always. If the numbers you want to multiply are small, then a combi multipiler is ok, as it is very easy to code, and can be written as a * sign anywhere in the code. You will hardly see a seq multiplier if 2 small numbers are being multiplied.
Kr,
avi
    natg9
Hi Avi
ok to be specific for my case i will be building a 8X8 multiplier
so is combinational better here
thanks for the earlier replies
