How to make 2w 1500-1600MHZ amp for FM modualtion
7rots51
How to make 2w 1500-1600MHZ amp for FM modualtion?which component or device is better? Is there any ready to buy module?
You may check RFMD.com and wj.com sites. These companies are making good amplifiers.
hi,
Tyco Electronics Power amplifier IC's and modules Available, modules costs more
WJ Communications also makes good amps
Mini-Circuits makes modules ......
the below image lists the companies, this table helps you finding a amp IC/Module
    7rots51
