Mandatory standards supported by 3G and 3GPP in mobiles
GVVIN
Full Member level 1
Should a 3G mobile handset support GSM and WCDMA. tri bands.
The classification 2G 3G DEPENDS ON DATA RATE.
ALSO
In 3GPP LTE is it mandatory that mobiles should be able to switch between GSM AND CDMA NETWORKS.FOR INTEROPERABILITY.
thanks and regards
GV
3G and 3GPP
This is not mandatory, it's depend on vendors and phone model. Many phones can support 2G, 3G and Wi-Fi at the same time.
    GVVIN
Re: 3G and 3GPP
so you mean to say in LTE it is not mandatory. It can be a standalone GSM or WCDMA , not that it should support both
I know in 3G it is not manadatory.
GV
Re: 3G and 3GPP
At least now LTE shall co-exist with other standards (GSM/GPRS and WCDMA/CDMA-EVDO) and should support them where LTE coverage is unavailable.
