Yep, any obstacle (imperfection) in a waveguide generetes high order modes.GGAPBE96 said:Impedance mismatch generate higher order modes?
GGAPBE96 said:To navuho,
Thank you.
I confused impedance mismatch with geometrical discontinuity.
Both obstacles violate the electromagnetic field..
wlcsp said:but does not necessarily mean it will generate higher-order mode. It may generate higher order mode if it reaches the cut-off freq depending on the er and etc, but not always.
wlcsp
Yes, you are right. If the impeadnce mismatch caused only by media properties changing (εr, µr) then no high order modes will be generated near such a boundary.wlcsp said:This means you will have an impedance mismatch, but does not necessarily mean it will generate higher-order mode.
In that case I think higher order modes will be not generated at all regardless of εr.It may generate higher order mode if it reaches the cut-off freq depending on the εr and etc, but not always.
AgreeWhile, I guess discontinuity (step, bend, and etc) will always generate higher-order modes which may or may not die along line as it propagates.
