John_li
Full Member level 5
- Joined
- Aug 6, 2005
- Messages
- 272
- Helped
- 9
- Reputation
- 18
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 2,945
hi all,
I want to matching LNA for the noise,assume the Gamma(opt)=0.13/124.48,there is two matching path:from 50 Ohm to Zopt,or Zopt to 50 Ohm.In my mind,it is the different topology.and the last one is convenient and accurate to operate in smithchart.But more ducument select the first.Which one i should select?Why?
Thank you,
Thank you,
