How to convert ASCII characters into numeric values in KEIL
te04-0202
Junior Member level 1
keil itoa
How to convert ASCII characters into numeric values in KEIL COMPILER.
keil ascii to character
if you want to convert a single character :
char c = '5';
int a = c - '0'; // now a = 5
if you want to convert an ascii array:
int a = 0;
char num[] = {'1' , '9' , '3' };
a = conv( num , 3 ); // now ans=193
int conv( char arr[] , char len )
    int ans = 0;
    char i;
    for( i = 0 ; i < len; i++ )
        ans *= 10;
        ans += arr[i]-'0';
    return ans;
    te04-0202
character ascii keil c
HAI,
you can use below a to i function in keil also.nothing wrong.
int i;
char s [] = "12345";
i = atoi (s);
    te04-0202
keil char to ascii
How to convert an integer into character.
keil get ascii code
I think you can try to use the fomula.
No = No * 10 + ch - '0';
Good Luck.
    te04-0202
Re: How to convert ASCII characters into numeric values in K
HAI,
for this you have to use itoa.
