Analog vs Digital > semiconductor
enigma^6
Junior Member level 1
What's the difference of Analog vs Digital with respect to semiconductors with respect to construction, application and circuit itself?
Digital is just analog circuits operating in the extreme modes
(Cut off & Saturation / Cut off & Active ) to provide logic low and high.
CMOS (MOsfets) are used for digital to save power.
Added after 56 seconds:
    enigma^6
There are different design rules for different kinds of circuits, and not just if analog or digital.
For instance - RF in digital circuits we usually want to avoid, but in radio circuits - we want to filter and amplify them.
And of course we can use RF for analog or digital transmissions, and maybe even use same components - sometimes its just a matter of modulation techniques.
One guy answered rightly that e.g transistor is when used as amplifier, it is used in ACTIVE region. when used as a switch it is used in CUT-OFF and SATURATION region. so u might be amplifying a A.C signal in ACTIVE region, and in DIGITAL switch u might be using it in the other two regions.
some circuits are used specially as digital like logic gates, flip-flops and other higher circuits.
hope it will help.
Naveed
