Where is the "Global" option in DXP?
smmiri1360
Junior Member level 1
hi
i'm searching for "Global" option in DXP.
in Protel99se there is a option in component properties window,"Global"
Now i can't find the equivalent option in ProtelDXP.
Could anyone please help me?
Re: global??
Hi,I don't know about dxp but I think it is like altum designer 2006.I asked this question about altum 6 on this forum and this is the answer by House_Cat:
- Right Click on the type of object you want to change globally.
- Select "Find Similar Objects" at the top of the right click menu
- Use the dialog that appears to select the criteria to match, and make sure the box at the bottom of the dialog to "Run Inspector" is checked.
- When the Inspector Panel opens, change whatever properties you want to change globally, and hit Enter (Return) on your keyboard. All of the matched items will change on your PCB.
You have the same kind of capability in the Schematic Editor, and you do it the same way. In addition to the above method, you can select the objects you want to change on the PCB or Schematic, and hit the "F11" key to bring up the Inspector Panel. Whatever you change in the panel will change on the PCB or Schematic.
All of this information can be found by going to Help>>Getting Started>>Editing Multiple Objects in the @ltium Designer menu, or by going directly to the document "TU0115 Editing Multiple Objects.pdf" in the "Help" folder of your installation.
I hope it will be helpful.
    smmiri1360
