Jim cage
Full Member level 2
Hi All,
1- Is Rake receiver unique for CDMA only? if it solves the problem of multipath why it is not used in other types of communication systems for example 802.11a/g or gsm?
2- If the incoming signal has two paths with opposite phase (which cancell each other) how would rake receiver solve the problem of the multipath? the signal is Zero at the input due to multipath. Does anyone knows the answer?
Thanks,
Thanks,
