vlsitechnology
Full Member level 5
1) Design a circuit which will either substract x from y or y from x, depending on the value of a .If a=1, the output should be x-y, and if a=0, the output should be y-x.Use a 4 bit substractor and two 4bit 2to 1 mux?
2) Realize a full adder using a 3 to 8 line decoder and a)two or gates b)two norgates
