Help me correct code for modular division
simu
Junior Member level 3
India
hi
i have written a coding for modular division.. and while compiling i didn't get any error. but while simulating using modelsim the i/o lines donot occur in the screen. also the run command is not active...so even if i enter the input values i couldn't run.. can u please help me correcting it....
code correction
u check with ur clock input . I also faced the same problem once.
    simu
Re: code correction
still facing problem... the i/o lines not found and the run cmd is not active...
Re: code correction
did you add the input and output and signals to the wave window....
    simu
Re: code correction
yes.... i have added... the i/o is mentioned in the o/p window... but the lines are not found(blue and red lines in modelsim) and also the run cmd is not active...
Re: code correction
never use "assign" statement in the initial or always block..
correct code is attached here...
    simu
