Allegro PCB v16: changing colors of the ratnest to nets?
Batke
Member level 4
Member level 4
PCB_LAND
Allegro changing colors
Allegro PCB v16:
Is it possible to change colors of the ratnest to particular nets?
(gnd in one color, vcc in other, clocks in other and so on ?)
this feature was one of the Orcad Layout best things.
regards,
Batke
Re: Allegro changing colors
Yes it is possible. You only have to highlight the net and the rat will take on the colour you use. Also a good idea is to have solid hilight on instead of zebra highlight, the ratnest has a zero line width and the highlight may not show up properly on zebra.
regards
Scott
    Batke
It worked.
Thank you.
But how to change ratnest from zebra to solid line ?
The highlight solid or striped is a user preference setting.
we have it so we can change it using the functions keys (this is set in the pcb env file).
However you can find the setting by going to setup/user preferences and going to the display folder then go to the preference 'display_nohilitefont' if it is ticked then the highlight should be solid unticked and it will be striped.
Hope this helps and doesn't confuse too much
It worked, again.
thanx .
