Synopsys HSPICE Installation
AdvaRes
At home
hspice installation
Hi all,
I installed Synopsys HSPICE 2007 ver-z-2007.03 (windows version) and I have to setup LM_License. Please show me how.
I have the sme problem with the ver-z-2007.09
Thanks in advance.
hspice instal
AdvaRes said:
Hi all,
Thanks in advance.
Under linux you just have to point the environment variable SNPSLMD_LICENSE_FILE or LM_LICENSE_FILE to your license.dat file.
Just look here **broken link removed**
things changed with 2007.9 .
Are you running it under linux btw ?
Hope this helps.
    AdvaRes
hspice installation guide
Thank dude for your prompt reply,
I'm using a Windows version. Could you tell me how ?
synopsys hspice 2007
1. Right-click My Computer, and then click Properties.
2. Click the Advanced tab.
3. Click Environment variables.
4. Click New, the variable name is SNPSLMD_LICENSE_FILE or LM_LICENSE_FILE, value is your license file.
hspice 2008 license windows
I am new to linux/ubuntu.
I installed wine and then installed hspice 2007.3. How would I redirect the license path in linux? also, where should it be re-directed to?
thanks
synopsys hspice academic license
thanks
I would recommend you get hold of the linux version and use that, running native apps is always preferable but if you still wish to use the windows version of hspice through wine then I believe this is what you want https://www.winehq.org/docs/wineusr-guide/environment-variables
You should tell it where your license file is ... the rest should have been taken care of by the installer.
Also besides the possible problem of running a windows app in wine I guess it may be a bit messy too.
Re: synopsys hspice academic license
I installed Synopsys HSPICE 2007 ver-z-2007.03. Hspui works normally but not the HspiceRF. When I use it I found "Error: Failed to checkout (hspicerf) license token."!!
