Problem with Spectre Monte Carlo Analysis
wjxcom
Full Member level 5
Full Member level 5
spectre distributed monte carlo mps
Hi all:
I designed a comparator, in the comparator circuit, the W, L and M of the Input Transistor(NMOS) is 2u, 1.5u and 2.
But when I perform the Monte Carlo Analysis, there have a problem: I modified the M of the Input Transistor 2 to 8, I found that the simulation result is not changed! i.e. the simulation result of M=2 is all the same to the simulation result of M=8!
I don't think this simulation result is right! the simulation result shouldn't be the same. I do not know what's wrong with the simulation! Help me please, thanx!!
monte carlo spectre expressions
Try to use instead of parameter M parallel transistors, for example M1 <1:8>.
    wjxcom
Hi pit1000: would you tell me why the simulation result is not right whtn I use the parameter M?
The multiplication factor not affect variations parameters.
    wjxcom
