santhosh.mandugula
Member level 5
hi everyone.........
(1) What are the specifications provided by a circuit design engineer to a layout engineer to draw the layout of passive elements (R, L and C)???
(2) For suppose to draw the layout of resistor (R), he will provide length(L), width(W) and type of the resistor to be drawn (polyres or diffusion res ). Like that what are the specifications provided to draw layout of L and C? Is he specifies the layers to be used before(For example metals to be used to form MIM capcitance)?
(3) What is meant by inner radius of the inductor?? (To draw the layout of inductor, inner radius significance)
If any material or screen shots are there, please upload. It will be helpful.
Thanking you,
santhosh
Thanking you,
santhosh
