What is the main role of the polyphase filters in RF transceivers?
drabos
Full Member level 6
Full Member level 6
Re: poly phase filters
To generate I and Q signal
    drabos
poly phase filters
they are used extensively IQ modulators and demodulators , to genarte I and Q signals from the LO
khouly
    drabos
poly phase filters
1. Splite the RF signal to 0deg and 90deg for IQ or image rejection usage.
2. Notch filter for image rejection.
    drabos
poly phase filters
and what are the other possibilities to generate I and Q signals? What is the advantage of polyphase filters?
What is the advantage of Legendre polynomial filters?
poly phase filters
other posiblities , it use some sort of frequqcy dividers , so if the LO is 2 or 4 times , no need for the poly phase filter
but if ur LO is the same freq , u need a poly phase filter
khouly
    drabos
poly phase filters
Hi Khouly
Can you recommend me a good literature in this topic?
They are mainly used as channel filter in combination with quadrature mixer to filter the image signal in Receiver and generate I and Q signal.
Hereafter you can find some references on this issue:
"CMOS mixers and polyphase filters for large image rejection" from Behbahani, F.; Kishigami, Y.; Leete, J.; Abidi, A.A.
    drabos
I think it is image frequency rejection.
